keep remote update fails to copy files to remote server
mikep
Ottawa
I have been using this feature in WinSCP for years. It is even more important as i am working from home now. what happens is that on occasion it seems that the file copy dialog is trying to copy a file back to the server and it times out followed by a loss of connection. I need to close the program and restart it for this feature to work again. This is an intermittent problem that occurs occasionally but often happens after long periods of inactivity like going for dinner and then coming back to do some more work. This has only been occurring in the last few versions going back to earlier this year (2020)
Re: keep remote update fails to copy files to remote server
After the reconnect, the function should keep working. Restart should not be needed.
Can you identify the version that introduced the problem?
https://sourceforge.net/projects/winscp/files/WinSCP/
