font size on putty
I use winscp on window 10 pro with putty (rev up to date).
Is there a way to tell winscp to force the font size on the putty opened session
I don't want to creat a specifique putty config for each machine.
I want to use the winscp automatique created temporary session, whish should be able to force a font size.
I didn't find any spécifiques params for this on the winscp session config.
I tryed to pass a putty cmd line option (-fn "Monospace 12" for exemple) in the winscp session param environnement/putty parametres.
but it seams that the windows version of putty didn't recognize the -fn param (it works fine on linux version) I tried it on power shell. -> "cmdline Error"
anybody know a way to avoyd me to create a new putty session for each winscp session ?
regards,
regards,
