Download Files based on extension
PPATEL
I want to download a file using C# WINSCP based on file extension. Here is my code to do that, but it doesn't work.
session.GetFiles(remoteLocation + "*txt", localDestination, delRemoteFile, transferOptions);
AM I missing anything?
This code below:
Downloads all the files.
session.GetFiles(remoteLocation + "*", localDestination, delRemoteFile, transferOptions);
Re: Download Files based on extension
Make sure that the remoteLocation ends with a slash.
Basically, you need:
session.GetFiles("/remote/location/*.txt", ...);
Easier might be to use Session.GetFilesToDirectory. With it, you do not have to deal with the slashes:
session.GetFilesToDirectory(remoteLocation, localDestination, "*.txt", delRemoteFile, transferOptions);
https://winscp.net/eng/docs/library_session_getfilestodirectory
See also https://winscp.net/eng/docs/faq_script_vs_gui#inputs
