Using .NET assembly to remove folder
ramc10
I have an SFTP site were files are delivered in a folder, were the folder name would be the previous day date. If it's 8th October the folder would be 20201007. After that the files are downloaded, I need to remove the folder with all of its contents.
I configured the below variables in the script
$yesterday = (Get-date).AddDays(-1)
$timestamp = $yesterday.ToString("yyyyMMdd")
Then I'm trying to remove the folder using the below command
Session.RemoveFile(RemotePath.EscapeFileMask(/folder/$timestamp))
I'm being prompted /folder/$timestamp isn't recognized.
Regards
RamC
Re: using .NetAssembly to remove folder
Because that's not a valid PowerShell code. It looks more like C#, but it's not valid C# either.
Also with Session.RemoveFile, do not use RemotePath.EscapeFileMask.
It should be like:
$session.RemoveFile("/folder/$timestamp")
(assuming you have $session variable with an instance of Session class)
