Powershell WinSCPnet, not deleting remote files when using $session.RemoveFiles()
chrsjo
malmö
I struggle to get the RemoveFiles() function to delete remote files. Using the WinSCPnet in a PowerShell script.
The errormessage I get is "{WinSCP.SessionRemoteException: Can't get attributes of file "
This is the barebone code I am trying.
Grateful for any assistance, or alternative ways to solve the problem
Add-Type -Path "C:\Program Files (x86)\WinSCP\WinSCPnet.dll"
    Protocol = [WinSCP.Protocol]::ftp
    HostName = "xxxxx"
    UserName = "xxxxx"
    password = "xxxxx"
$session.ExecutablePath = "C:\Program Files (x86)\WinSCP\winscp.exe"
try
    # Connect
    $transferOptions.TransferMode = [WinSCP.TransferMode]::Binary
    #Listing remote directory to avoid the problem of how the file is named.
    # NOT all remote files should be deleted, in real life I would like to loop through a list
    # local filenames that should be deleted on the remote location
    $Directory = $session.ListDirectory("/")
    foreach ($FileInfo in $Directory.Files)
     $RemovalFile = ($FileInfo.Name)
     $session.RemoveFiles($RemovalFile)
finally
    $session.Dispose()
Re: Powershell WinSCPnet, not deleting remote files when using $session.RemoveFiles()
It should be:
$RemovalFile = $FileInfo.FullName
Or even better:
$RemovalFile = [WinSCP.RemotePath]::EscapeFileMask($FileInfo.FullName)
If this does not help, please attach a full session log file showing the problem (using the latest version of WinSCP).
