Deleting files off remote FTP folder after download
DDye
I am trying to delete files off a remote FTP server after successful download using PowerShell. I found this example and tried it:
Deleting remote files after successful remote to local synchronization
In the console it shows that the file was deleted, but after refreshing the folder the files are still there.
Any help would be appreciated.
param (
    $localPath = "C:\backup\",
    $remotePath = "/home/user/data/"
try
    # Load WinSCP .NET assembly
    Add-Type -Path "WinSCPnet.dll"
    # Setup session options
        HostName = "example.com"
        UserName = "user"
        Password = "mypassword"
        SshHostKeyFingerprint = "ssh-rsa 2048 xxxxxxxxxxx...="
    try
        # Connect
        # Synchronize files to local directory, collect results
        $synchronizationResult = $session.SynchronizeDirectories(
            [WinSCP.SynchronizationMode]::Local, $localPath, $remotePath, $False)
        # Deliberately not calling $synchronizationResult.Check
        # as that would abort our script on any error.
        # We will find any error in the loop below
        # (note that $synchronizationResult.Downloads is the only operation
        # collection of SynchronizationResult that can contain any items,
        # as we are not removing nor uploading anything)
        # Iterate over every download
        foreach ($download in $synchronizationResult.Downloads)
            # Success or error?
            if ($download.Error -eq $Null)
                Write-Host "Download of $($download.FileName) succeeded, removing from source"
                # Download succeeded, remove file from source
                $filename = [WinSCP.RemotePath]::EscapeFileMask($download.FileName)
                $removalResult = $session.RemoveFiles($filename)
                if ($removalResult.IsSuccess)
                    Write-Host "Removing of file $($download.FileName) succeeded"
                else
                    Write-Host "Removing of file $($download.FileName) failed"
            else
                Write-Host (
                    "Download of $($download.FileName) failed: $($download.Error.Message)")
    finally
        # Disconnect, clean up
        $session.Dispose()
    exit 0
catch
    exit 1
Re: Deleting files off remote ftp folder after download
First, if you want to download and delete files, just use simple:
$session.GetFilesToDirectory($remotePath, $localPath, $Null, $True).Check()
That's all it takes. No need for that complicate code (which is about synchronization, not plain download).
If this does not work, add $session.ListDirectory($remotePath) after the $session.GetFilesToDirectory and post a full session log file showing the problem (using the latest version of WinSCP).
