Could not get directory listing Error trying to browse directory
RaulSoni
MEXICO
Hi
Install WinSCP on a PC with Windos 10
1- Configure the Firewall to allow WinSCP applications to pass through the Firewall.
2- Also add a new inbound rule for port 21 for TCP protocol.
3- Also add an exclusion for the WinSCP application in Virus & Threat protection.
But when trying to connect to the server by FTP I get this error:
Disconnected from server
The solution I found was to turn off the Private Network Firewall and the Public Network Firewall is on.
How can I solve this Error when trying to browse the directory without having to turn off the Private Network firewall ???
Reply with quote E-mail
Re: Could not get directory listing Error trying to browse directory
I attach the Log you are requesting.
. 2020-11-15 14:27:47.019 --------------------------------------------------------------------------
. 2020-11-15 14:27:47.020 WinSCP Versión 5.17.8 (Compilación 10803) (OS 10.0.18363 - Windows 10 Enterprise)
. 2020-11-15 14:27:47.020 Configuration: nul
. 2020-11-15 14:27:47.021 Log level: Normal
. 2020-11-15 14:27:47.021 Local account: GEMSAPC1\GEMSA
. 2020-11-15 14:27:47.021 Working directory: C:\Respaldo
. 2020-11-15 14:27:47.021 Process ID: 6404
. 2020-11-15 14:27:47.022 Command-line: "C:\Program Files (x86)\WinSCP\WinSCP.exe" /console=5.17.8 /consoleinstance=_7740_261 "/ini=nul" "/log=logftp.txt" "/script=C:\RESPALDO\Script_FTP.txt"
. 2020-11-15 14:27:47.022 Time zone: Current: GMT-6, Standard: GMT-6 (Hora estándar central (México)), DST: GMT-5 (Hora de verano central (México)), DST Start: 05/04/2020, DST End: 25/10/2020
. 2020-11-15 14:27:47.023 Login time: domingo, 15 de noviembre de 2020 02:27:47 p. m.
. 2020-11-15 14:27:47.023 --------------------------------------------------------------------------
. 2020-11-15 14:27:47.023 Script: Retrospectively logging previous script records:
> 2020-11-15 14:27:47.023 Script: Open FTP://Raul:***@****PCDell.ddns.***/
. 2020-11-15 14:27:47.023 Session name: Raul@****PCDell.ddns.*** (Ad-Hoc site)
. 2020-11-15 14:27:47.023 Host name: ****PCDell.ddns.*** (Port: 21)
. 2020-11-15 14:27:47.024 User name: Raul (Password: Yes, Key file: No, Passphrase: No)
. 2020-11-15 14:27:47.024 Transfer Protocol: FTP
. 2020-11-15 14:27:47.024 Ping type: Dummy, Ping interval: 30 sec; Timeout: 15 sec
. 2020-11-15 14:27:47.024 Disable Nagle: No
. 2020-11-15 14:27:47.024 Proxy: None
. 2020-11-15 14:27:47.024 Send buffer: 262144
. 2020-11-15 14:27:47.024 UTF: Auto
. 2020-11-15 14:27:47.024 FTPS: None [Client certificate: No]
. 2020-11-15 14:27:47.024 FTP: Passive: Yes [Force IP: Auto]; MLSD: Auto [List all: Auto]; HOST: Auto
. 2020-11-15 14:27:47.024 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2020-11-15 14:27:47.024 Cache directory changes: Yes, Permanent: Yes
. 2020-11-15 14:27:47.024 Recycle bin: Delete to: No, Overwritten to: No, Bin path:
. 2020-11-15 14:27:47.024 Timezone offset: 0h 0m
. 2020-11-15 14:27:47.024 --------------------------------------------------------------------------
. 2020-11-15 14:27:47.058 Conectando con ****PCDell.ddns.***...
. 2020-11-15 14:27:47.229 Conectado con ****PCDell.ddns.***. Esperando bienvenida...
< 2020-11-15 14:27:47.243 220-FileZilla Server 0.9.60 beta
< 2020-11-15 14:27:47.243 220-written by Tim Kosse (tim.kosse@filezilla-project.org)
< 2020-11-15 14:27:47.243 220 Please visit https://filezilla-project.org/
> 2020-11-15 14:27:47.243 USER Raul
< 2020-11-15 14:27:47.253 331 Password required for raul
> 2020-11-15 14:27:47.253 PASS ********
< 2020-11-15 14:27:47.382 230 Logged on
> 2020-11-15 14:27:47.382 SYST
< 2020-11-15 14:27:47.390 215 UNIX emulated by FileZilla
> 2020-11-15 14:27:47.390 FEAT
< 2020-11-15 14:27:47.398 211-Features:
< 2020-11-15 14:27:47.398  MDTM
< 2020-11-15 14:27:47.398  REST STREAM
< 2020-11-15 14:27:47.399  SIZE
< 2020-11-15 14:27:47.399  MLST type*;size*;modify*;
< 2020-11-15 14:27:47.399  MLSD
< 2020-11-15 14:27:47.399  UTF8
< 2020-11-15 14:27:47.399  CLNT
< 2020-11-15 14:27:47.399  MFMT
< 2020-11-15 14:27:47.399  EPSV
< 2020-11-15 14:27:47.399  EPRT
< 2020-11-15 14:27:47.399 211 End
> 2020-11-15 14:27:47.399 CLNT WinSCP-release-5.17.8
< 2020-11-15 14:27:47.407 200 Don't care
> 2020-11-15 14:27:47.407 OPTS UTF8 ON
< 2020-11-15 14:27:47.418 202 UTF8 mode is always enabled. No need to send this command.
. 2020-11-15 14:27:47.419 Conectado
. 2020-11-15 14:27:47.419 --------------------------------------------------------------------------
. 2020-11-15 14:27:47.436 Using FTP protocol.
. 2020-11-15 14:27:47.445 Doing startup conversation with host.
> 2020-11-15 14:27:47.447 PWD
< 2020-11-15 14:27:47.456 257 "/" is current directory.
. 2020-11-15 14:27:47.457 Getting current directory name.
. 2020-11-15 14:27:47.457 Startup conversation with host finished.
< 2020-11-15 14:27:47.458 Script: Sesión activa: [1] Raul@****PCDell.ddns.***
> 2020-11-15 14:27:47.460 Script: Put C:\Respaldo\*.* /GEMSA_Server1/*.*
. 2020-11-15 14:27:47.487 Copying 6 files/directories to remote directory "/GEMSA_Server1/"
. 2020-11-15 14:27:47.488   PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 0100; Resume: S (102400); CalcS: No; Mask: *.*
. 2020-11-15 14:27:47.488   TM: B; ClAr: No; RemEOF: No; RemBOM: No; CPS: 0; NewerOnly: No; EncryptNewFiles: Yes; ExcludeHiddenFiles: No; ExcludeEmptyDirectories: No; InclM: ; ResumeL: 0
. 2020-11-15 14:27:47.488   AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; *.js; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2020-11-15 14:27:47.490 File: 'C:\Respaldo\FTP_Gemsa_PCDell.bat' [2020-11-15T20:26:16.510Z] [102]
. 2020-11-15 14:27:47.492 Copying "C:\Respaldo\FTP_Gemsa_PCDell.bat" to remote directory started.
. 2020-11-15 14:27:47.492 Binary transfer mode selected.
. 2020-11-15 14:27:47.493 Iniciando la subida de C:\Respaldo\FTP_GEMSA_PCDell.bat
> 2020-11-15 14:27:47.493 CWD /GEMSA_Server1
< 2020-11-15 14:27:47.520 250 CWD successful. "/GEMSA_Server1" is current directory.
> 2020-11-15 14:27:47.520 PWD
< 2020-11-15 14:27:47.528 257 "/GEMSA_Server1" is current directory.
> 2020-11-15 14:27:47.535 TYPE I
< 2020-11-15 14:27:47.547 200 Type set to I
> 2020-11-15 14:27:47.547 PASV
. 2020-11-15 14:27:47.555 Desconectado del servidor
. 2020-11-15 14:27:47.555 Ha ocurrido un error al intentar copiar los archivos a la ubicación remota.
. 2020-11-15 14:27:47.574 Connection was lost, asking what to do.
. 2020-11-15 14:27:47.574 Asking user:
. 2020-11-15 14:27:47.574 **La conexión se ha perdido.** ("Desconectado del servidor","Ha ocurrido un error al intentar copiar los archivos a la ubicación remota.")
< 2020-11-15 14:27:47.574 Script: La conexión se ha perdido.
< 2020-11-15 14:27:47.575 Script: Desconectado del servidor
< 2020-11-15 14:27:47.575 Ha ocurrido un error al intentar copiar los archivos a la ubicación remota.
< 2020-11-15 14:27:52.729 Script: Conectando con ****PCDell.ddns.***...
. 2020-11-15 14:27:52.730 Conectando con ****PCDell.ddns.***...
. 2020-11-15 14:27:52.745 Conectado con ****PCDell.ddns.***. Esperando bienvenida...
< 2020-11-15 14:27:52.755 220-FileZilla Server 0.9.60 beta
< 2020-11-15 14:27:52.756 220-written by Tim Kosse (tim.kosse@filezilla-project.org)
< 2020-11-15 14:27:52.756 220 Please visit https://filezilla-project.org/
> 2020-11-15 14:27:52.756 USER Raul
< 2020-11-15 14:27:52.769 331 Password required for raul
> 2020-11-15 14:27:52.769 PASS ********
< 2020-11-15 14:27:52.774 230 Logged on
> 2020-11-15 14:27:52.774 SYST
< 2020-11-15 14:27:52.791 215 UNIX emulated by FileZilla
> 2020-11-15 14:27:52.791 FEAT
< 2020-11-15 14:27:52.800 211-Features:
< 2020-11-15 14:27:52.800  MDTM
< 2020-11-15 14:27:52.800  REST STREAM
< 2020-11-15 14:27:52.800  SIZE
< 2020-11-15 14:27:52.800  MLST type*;size*;modify*;
< 2020-11-15 14:27:52.800  MLSD
< 2020-11-15 14:27:52.800  UTF8
< 2020-11-15 14:27:52.801  CLNT
< 2020-11-15 14:27:52.801  MFMT
< 2020-11-15 14:27:52.801  EPSV
< 2020-11-15 14:27:52.801  EPRT
< 2020-11-15 14:27:52.801 211 End
> 2020-11-15 14:27:52.801 CLNT WinSCP-release-5.17.8
< 2020-11-15 14:27:52.809 200 Don't care
> 2020-11-15 14:27:52.810 OPTS UTF8 ON
< 2020-11-15 14:27:52.815 202 UTF8 mode is always enabled. No need to send this command.
< 2020-11-15 14:27:52.815 Script: Conectado
. 2020-11-15 14:27:52.816 Conectado
. 2020-11-15 14:27:52.816 Doing startup conversation with host.
< 2020-11-15 14:27:52.816 Script: Iniciando la sesión...
> 2020-11-15 14:27:52.817 PWD
< 2020-11-15 14:27:52.825 257 "/" is current directory.
. 2020-11-15 14:27:52.826 Changing directory to "/".
> 2020-11-15 14:27:52.826 CWD /
< 2020-11-15 14:27:52.837 250 CWD successful. "/" is current directory.
. 2020-11-15 14:27:52.838 Getting current directory name.
> 2020-11-15 14:27:52.838 PWD
< 2020-11-15 14:27:52.847 257 "/" is current directory.
. 2020-11-15 14:27:52.847 Startup conversation with host finished.
< 2020-11-15 14:27:52.847 Script: Sesión iniciada.
. 2020-11-15 14:27:52.848 File: 'C:\Respaldo\FTP_Gemsa_PCDell.bat' [2020-11-15T20:26:16.510Z] [102]
. 2020-11-15 14:27:52.849 Copying "C:\Respaldo\FTP_Gemsa_PCDell.bat" to remote directory started.
. 2020-11-15 14:27:52.849 Binary transfer mode selected.
. 2020-11-15 14:27:52.849 Iniciando la subida de C:\Respaldo\FTP_Gemsa_PCDell.bat
> 2020-11-15 14:27:52.850 CWD /GEMSA_Server1
< 2020-11-15 14:27:52.859 250 CWD successful. "/GEMSA_Server1" is current directory.
> 2020-11-15 14:27:52.859 PWD
< 2020-11-15 14:27:52.868 257 "/GEMSA_Server1" is current directory.
> 2020-11-15 14:27:52.868 TYPE A
< 2020-11-15 14:27:52.879 200 Type set to A
> 2020-11-15 14:27:52.879 PASV
. 2020-11-15 14:27:52.890 Desconectado del servidor
. 2020-11-15 14:27:52.890 Ha ocurrido un error al intentar copiar los archivos a la ubicación remota.
. 2020-11-15 14:27:52.891 Connection was lost, asking what to do.
. 2020-11-15 14:27:52.891 Asking user:
. 2020-11-15 14:27:52.891 **La conexión se ha perdido.** ("Desconectado del servidor","Ha ocurrido un error al intentar copiar los archivos a la ubicación remota.")
< 2020-11-15 14:27:52.891 Script: La conexión se ha perdido.
< 2020-11-15 14:27:52.892 Script: Desconectado del servidor
< 2020-11-15 14:27:52.892 Ha ocurrido un error al intentar copiar los archivos a la ubicación remota.
WinSCP does not even get a response to the PASV command. This does not look like a local machine problem. It's either server-side problem or a network problem. Can you transfer the files to/from the machine using any other FTP client or to/from any other machine or even any other network?
