Upload fails at target root
Hi All,
I'm trying to upload to the target root, but the failure, only authorizes if I do it if I do it in a folder inside the root.
The permissions are okay and I can do it with other tools like Core FTP.
Option batch continue Option confirm off open sftp://usr_999_9999@b2b.adpexpert.com.br:99999/ -privatekey*"C:\Key\XXX.ppk" . hostkey="ssh-rsa 1024 99:99:99:99:99:99:99:99:99:99:99:99" syncronize remote "D:\SFTP\LocalUser\ftp_telematica\Root" "/Root" -filemask"*.*>=today; |*/* -criteria="none" -resumesupport="off" -nopreservetime -nopermissions exit
Local 'D:\SFTP\LocalUser\ftp_telematica\ADP\Root' => Remote '/'
D:\SFTP\LocalUser\ftp_telematica\ADP\Root\AFD00100920201027020031.txt | 318 B | 0.0 KB/s | binary | 100%
Upload of file 'AFD00100920201027020031.txt' was successful, but error occurred while setting the permissions and/or timestamp.
If the problem persists, turn off setting permissions or preserving timestamp. Alternatively you can turn on 'Ignore permission errors' option.
Permission denied.
Error code: 3
Error message from server: This server does not support operations to modify file attributes. File attributes for [//AFD00100920201027020031.txt] were not modified.
(A)bort, (R)etry, (S)kip, Ski(p) all: Skip
