WinSCP window disappears in the middle of large file downloading
suelian
Australia
I tried to download a large folder from server to local drive using WinSCP 5.17, total size is approximately 950G.
I let it run overnight, because it needs to connect to an Ethernet cable in the office, and when I check it in the morning, the window is gone already (the PC wasn't down, just locked), and the drive shows last modified was at midnight, and only 450G out of total was downloaded.
I tried a second time, same thing happened, this time only downloaded 380G.
Pretty sure it's not network issue because it keeps plugged in with the Ethernet.
Can anyone help with this issue?
Re: WinSCP window disappears in the middle of large file downloading
