Error using move file
andybruner
I am getting this error when using move file. Can you help? Thanks.
General failure (server should provide error description).
Error code: 4
Error message from server: Failure
Here's my code:
    // Connect
    string sftpFolder = "/parcs/download/" + mSysParam.Company;
    mLgr.LogInfo(sftpFolder);
    session.Open(sessionOptions);
    // download files
    TransferOptions transferOptions = new TransferOptions();
    transferOptions.TransferMode = TransferMode.Binary;
    TransferOperationResult transferResult;
    transferResult =
        session.GetFilesToDirectory(sftpFolder, mApplicationDataPath);
    localPPCounter++; //increase PP count so loop will stop
    //// Print results
    foreach (TransferEventArgs transfer in transferResult.Transfers)
        mLgr.LogInfo("Download of file succeeded: " + transfer.FileName);
        mLgr.LogInfo("Destination:" + transfer.Destination);
    session.MoveFile("/parcs/download/","/parcs/download/PNB/Processed");
Re: error using move file
What are you actually trying to do? Your code does not seem to move a file. It moves a folder. The "Failure" might indicate that there already exists a folder (or a file) with that name in the target directory.
See https://winscp.net/eng/docs/sftp_codes#code_4
Didn't you actually want to move the files from the folder to the "processed" directory?
See Moving (not copying) remote files after download with WinSCP .NET assembly
