VMS FTP - File Specification Error
cmsjwilson
I'm attempting to copy files from a VMS server to a local directory using FTP protocol. During a file copy I receive a 'File Specification syntax error.'
Comparing file listing in 'Total Commander' GUI vs. 'WinSCP' GUI screens, I notice that WinSCP does not show the file extension numbers appended to the end of the filename. Ex: test.log;1
I know this is a VMS style dir/filename convention. Does WinSCP not support this?
I believe this is the main issue why I can't complete file transfers. Even though I receive the 'File Specification syntax error', an empty file (0 bytes) of the correct filename is created in the local directory. So, it somewhat works, but I believe the main issue is the VMS filename syntax.
Any help would be appreciated.
Chris
Re: VMS FTP - File Specification Error
In general, WinSCP does not have a full support for VMS.
Anyway, please attach a full session log file showing the problem (using the latest version of WinSCP).
cmsjwilson
Hi Martin,
Thanks for the response.
I tried:
get SDP_ERROR.LOG test.log
Same file specification error.
When using Total Commander and listing out a directory, the file revision number is shown appended to the end of each file:
SDP_ERROR.LOG;1
SDP_ERROR.LOG;2
SDP_ERROR.LOG;47
WinSCP only displays:
SDP_ERROR.LOG
So, I'm sure this is the main issue.
I've tried this code, but and error is displayed saying the SDP_ERROR.LOG;1 can't be found on remote server.
get SDP_ERROR.LOG;1 test.log
Here is how Total commander copies a file from the VMS server to local directory:
200 PORT command successful.
RETR SDP_ERROR.LOG;47
150 Opening data connection for SDP_ERROR.LOG;47 (15.97.254.111,56955)
Download
Waiting for server...
226 Transfer complete.
Copied (12/18/2020 5:14:53): ftp://15.97.254.181DKA300:[000000.MCSVLOG]/SDP_ERROR.LOG;47 -> C:\Nikon_File_Transfer\scripts\SDP_ERROR.LOG;47 178 bytes, 0 bytes/s
Chris
Please post a log file for that.
cmsjwilson
Hi Martin,
As per your request, please see attached log.
Error occurs when I attempt this:
get SDP_ERROR.LOG;47 test.log
Chris
  • win_scp2.log (49.23 KB, Private file)
cmsjwilson
Hi Martin,
As per your request I've added the 'ls' command prior to the 'get' command. Please see attached log.
Thank you,
Chris
  • win_scp3.log (82.11 KB, Private file)
Thanks. I'm sending you an email with a development version of WinSCP to the address you have used to register on this forum.
cmsjwilson
Thanks Martin.
I've replied to your email and attached the log files you requested.
Regards,
Chris
