Security: Bad IP connecting.
DanRotaru
Moldova
I try to connect using FTP but I always receive error "Security: Bad IP connecting." and I'm disconecting, what to do???
Server (hosting) does not matter, I receive that error on more hostings, please help!
Re: Security: Bad IP connecting.
How are you connected to the internet? Isn't it a mobile connection? It looks like the server sees the FTP data connection as coming from a different IP address than the control connection.
I do not know how you got two IP addresses. You are possibly connected to two networks. Disable one of them temporarily.
DanRotaru
I am connected to one wifi connection, 2 different sites to check my IP shows different ip address, in https://ipapi.co/ one and in google "my ip address" another, I think in this is problem, but how to fix it I don't know:(
IP address differs only by last number (xxx.xxx.xxx.this), first (xxx.xxx.xxx are the same)
Are those addresses stable? Or do they change over time? How is your wifi router connected to the Internet?
