Keep getting Cannot overwrite remote file
Swindellvc@cofc.edu
Charleston, SC
I have a vb.net program that I wrote to upload Student Photos that have been added in the last 14 days to a remote site, It keeps crashing with:
Cannot overwrite remote file <name> of file.
And I'm trying to find a work around.
code:
Dim mySessionOptions As New WinSCP.SessionOptions
    Dim PicCount As Integer = 0
    Static start_time As DateTime
    Static stop_time As DateTime
    Dim elapsed_time As TimeSpan
    Dim TOinterval As New TimeSpan(0, 30, 0)
    Dim MyTransferOptions As New TransferOptions
    start_time = Now
    mySession.DisableVersionCheck = False
    With mySessionOptions
        .Protocol = Protocol.Sftp
        .PortNumber = 22
        .HostName = "<site name>"
        .PrivateKeyPassphrase = classified
        .UserName = "cofc"
        .SshHostKeyFingerprint = <key>
        .SshPrivateKeyPath = "\\aiken\ProdCognos\ITExtracts\SSHKEY\myKey.ppk"
        .PrivateKeyPassphrase = <Phrase>
        .Timeout = New TimeSpan(0, 4, 30)
        .AddRawSettings("ConsiderDST", "0")
    End With
    'Connect
    mySession.Open(mySessionOptions)
    'Upload files
    With MyTransferOptions
        .TransferMode = TransferMode.Automatic
        .FileMask = "*>=14D"  'Transfer only files changed in the last 14 days
        .ResumeSupport.State = TransferResumeSupportState.Smart
        .PreserveTimestamp = False
        .OverwriteMode = OverwriteMode.Resume
    End With
    transferResult = mySession.PutFiles("\\aiken\IDPhotos\*.jpg", "/studentpics/", False, MyTransferOptions)
    'Throw on any error
    Try
        transferResult.Check()
    Catch ex As System.IO.IOException
        Console.WriteLine(ex.Message)
    End Try
    Dim transfer As TransferEventArgs
    For Each transfer In transferResult.Transfers
        Console.WriteLine("Upload of {0} succeeded" & vbCrLf, transfer.FileName)
        PicCount = PicCount + 1
    Next
    stop_time = Now
    elapsed_time = stop_time.Subtract(start_time)
    sMsg = sMsg & "A total of " & PicCount & " images  have been uploaded." & vbCrLf
    sMsg = sMsg & "Total elapsed time " & elapsed_time.TotalMinutes.ToString("0.000000") & " minutes."
Reply with quote E-mail
Re: Keep getting Cannot overwrite remote file
Swindellvc@cofc.edu
Charleston, SC
Log file
. 2020-12-18 09:52:18.454 --------------------------------------------------------------------------
. 2020-12-18 09:52:18.455 WinSCP Version 5.17.6 (Build 10516) (OS 10.0.17134 - Windows 10 Enterprise)
. 2020-12-18 09:52:18.455 Configuration: nul
. 2020-12-18 09:52:18.456 Log level: Normal
. 2020-12-18 09:52:18.457 Local account: COUGARS\REDACTED
. 2020-12-18 09:52:18.458 Working directory: C:\Program Files (x86)\WinSCP
. 2020-12-18 09:52:18.459 Process ID: 3444
. 2020-12-18 09:52:18.460 Command-line: "C:\Program Files (x86)\WinSCP\winscp.exe" /xmllog="C:\Users\Swindellvc\AppData\Local\Temp\wscp4B84.023404EE.tmp" /xmlgroups /xmllogrequired /nointeractiveinput /dotnet=5.17.6  /ini=nul /log="\\aiken\ProdItFileTrans\FILES\LOGS\PicsFileTrans.log"  /console /consoleinstance=_19332_25474675_795
. 2020-12-18 09:52:18.461 Time zone: Current: GMT-5, Standard: GMT-5 (Eastern Standard Time), DST: GMT-4 (Eastern Daylight Time), DST Start: 3/8/2020, DST End: 11/1/2020
. 2020-12-18 09:52:18.462 Login time: Friday, December 18, 2020 9:52:18 AM
. 2020-12-18 09:52:18.462 --------------------------------------------------------------------------
. 2020-12-18 09:52:18.463 Script: Retrospectively logging previous script records:
> 2020-12-18 09:52:18.464 Script: option batch on
< 2020-12-18 09:52:18.464 Script: batch           on
< 2020-12-18 09:52:18.465 Script: reconnecttime   120
> 2020-12-18 09:52:18.465 Script: option confirm off
< 2020-12-18 09:52:18.466 Script: confirm         off
> 2020-12-18 09:52:18.466 Script: option reconnecttime 120
< 2020-12-18 09:52:18.467 Script: reconnecttime   120
> 2020-12-18 09:52:18.467 Script: open sftp://cofc@sftp.us.erezlife.com:22 -hostkey="REDACTED" -privatekey="\\aiken\ProdCognos\ITExtracts\SSHKEY\myKey.ppk" -timeout=270 -passphrase=*** -rawsettings ConsiderDST="0"
. 2020-12-18 09:52:18.468 --------------------------------------------------------------------------
. 2020-12-18 09:52:18.468 Session name: cofc@sftp.us.erezlife.com (Ad-Hoc site)
. 2020-12-18 09:52:18.469 Host name: sftp.us.erezlife.com (Port: 22)
. 2020-12-18 09:52:18.470 User name: cofc (Password: No, Key file: Yes, Passphrase: Yes)
. 2020-12-18 09:52:18.470 Tunnel: No
. 2020-12-18 09:52:18.470 Transfer Protocol: SFTP
. 2020-12-18 09:52:18.471 Ping type: Off, Ping interval: 30 sec; Timeout: 270 sec
. 2020-12-18 09:52:18.471 Disable Nagle: No
. 2020-12-18 09:52:18.472 Proxy: None
. 2020-12-18 09:52:18.472 Send buffer: 262144
. 2020-12-18 09:52:18.473 SSH protocol version: 2; Compression: No
. 2020-12-18 09:52:18.474 Bypass authentication: No
. 2020-12-18 09:52:18.474 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: Yes
. 2020-12-18 09:52:18.474 GSSAPI: Forwarding: No; Libs: gssapi32,sspi,custom; Custom:
. 2020-12-18 09:52:18.475 Ciphers: aes,chacha20,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2020-12-18 09:52:18.475 KEX: ecdh,dh-gex-sha1,dh-group14-sha1,rsa,WARN,dh-group1-sha1
. 2020-12-18 09:52:18.476 SSH Bugs: Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto
. 2020-12-18 09:52:18.476 Simple channel: Yes
. 2020-12-18 09:52:18.477 Return code variable: Autodetect; Lookup user groups: Auto
. 2020-12-18 09:52:18.477 Shell: default
. 2020-12-18 09:52:18.478 EOL: LF, UTF: Auto
. 2020-12-18 09:52:18.478 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes; Follow directory symlinks: No
. 2020-12-18 09:52:18.479 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No; Exit code 1 is error: No
. 2020-12-18 09:52:18.479 SFTP Bugs: Auto,Auto
. 2020-12-18 09:52:18.480 SFTP Server: default
. 2020-12-18 09:52:18.480 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2020-12-18 09:52:18.481 Cache directory changes: Yes, Permanent: Yes
. 2020-12-18 09:52:18.481 Recycle bin: Delete to: No, Overwritten to: No, Bin path:
. 2020-12-18 09:52:18.482 DST mode: Win
. 2020-12-18 09:52:18.482 --------------------------------------------------------------------------
. 2020-12-18 09:52:18.484 Looking up host "sftp.us.erezlife.com" for SSH connection
. 2020-12-18 09:52:18.494 Connecting to 54.81.68.171 port 22
. 2020-12-18 09:52:18.570 We claim version: SSH-2.0-WinSCP_release_5.17.6
. 2020-12-18 09:52:18.571 Remote version: SSH-2.0-OpenSSH_7.4
. 2020-12-18 09:52:18.571 Using SSH protocol version 2
. 2020-12-18 09:52:18.572 Have a known host key of type ssh-ed25519
. 2020-12-18 09:52:18.597 Doing ECDH key exchange with curve Curve25519 and hash SHA-256
. 2020-12-18 09:52:18.740 Server also has ecdsa-sha2-nistp256/ssh-rsa host keys, but we don't know any of them
. 2020-12-18 09:52:18.741 Host key fingerprint is:
. 2020-12-18 09:52:18.741 ssh-REDACTED=
. 2020-12-18 09:52:18.742 Host key matches configured key fingerprint
. 2020-12-18 09:52:18.743 Initialised AES-256 SDCTR (AES-NI accelerated) outbound encryption
. 2020-12-18 09:52:18.744 Initialised HMAC-SHA-256 outbound MAC algorithm
. 2020-12-18 09:52:18.744 Initialised AES-256 SDCTR (AES-NI accelerated) inbound encryption
. 2020-12-18 09:52:18.745 Initialised HMAC-SHA-256 inbound MAC algorithm
. 2020-12-18 09:52:18.766 Reading key file "\\aiken\ProdCognos\ITExtracts\SSHKEY\myKey.ppk"
! 2020-12-18 09:52:18.771 Using username "REDACTED".
. 2020-12-18 09:52:19.609 Server offered these authentication methods: publickey
. 2020-12-18 09:52:19.610 Offered public key
. 2020-12-18 09:52:19.697 Offer of public key accepted
! 2020-12-18 09:52:19.698 Authenticating with public key "REDACTED"
. 2020-12-18 09:52:19.699 Prompt (passphrase, "SSH key passphrase", <no instructions>, "Passphrase for key "REDACTED": ")
. 2020-12-18 09:52:19.699 Using configured passphrase.
. 2020-12-18 09:52:19.884 Sent public key signature
. 2020-12-18 09:52:19.936 Access granted
. 2020-12-18 09:52:19.938 Opening main session channel
. 2020-12-18 09:52:20.206 Opened main channel
. 2020-12-18 09:52:20.309 Started a shell/command
. 2020-12-18 09:52:20.310 --------------------------------------------------------------------------
. 2020-12-18 09:52:20.310 Using SFTP protocol.
. 2020-12-18 09:52:20.311 Doing startup conversation with host.
> 2020-12-18 09:52:20.312 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2020-12-18 09:52:20.394 Type: SSH_FXP_VERSION, Size: 150, Number: -1
. 2020-12-18 09:52:20.395 SFTP version 3 negotiated.
. 2020-12-18 09:52:20.395 Unknown server extension posix-rename@openssh.com="1"
. 2020-12-18 09:52:20.396 Supports statvfs@openssh.com extension version "2"
. 2020-12-18 09:52:20.397 Unknown server extension fstatvfs@openssh.com="2"
. 2020-12-18 09:52:20.397 Supports hardlink@openssh.com extension version "1"
. 2020-12-18 09:52:20.398 Unknown server extension fsync@openssh.com="1"
. 2020-12-18 09:52:20.398 We believe the server has signed timestamps bug
. 2020-12-18 09:52:20.399 We will use UTF-8 strings until server sends an invalid UTF-8 string as with SFTP version 3 and older UTF-8 strings are not mandatory
. 2020-12-18 09:52:20.399 Limiting packet size to OpenSSH sftp-server limit of 262148 bytes
. 2020-12-18 09:52:20.400 Getting current directory name.
. 2020-12-18 09:52:20.400 Getting real path for '.'
> 2020-12-18 09:52:20.401 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2020-12-18 09:52:20.423 Type: SSH_FXP_NAME, Size: 23, Number: 16
. 2020-12-18 09:52:20.424 Real path is '/'
. 2020-12-18 09:52:20.425 Startup conversation with host finished.
< 2020-12-18 09:52:20.425 Script: Active session: [1] cofc@sftp.us.erezlife.com
> 2020-12-18 09:52:20.972 Script: pwd
< 2020-12-18 09:52:20.973 Script: /
> 2020-12-18 09:52:21.033 Script: put  -nopermissions -nopreservetime -transfer="automatic" -filemask="*>=14D" -resumesupport="100" -resume -- "\\aiken\IDPhotos\*.jpg" "/studentpics/"
. 2020-12-18 09:53:21.884 Copying 49519 files/directories to remote directory "/studentpics/" - total size: 2,608,605,894
. 2020-12-18 09:53:21.885   PrTime: No; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 0100; Resume: S (102400); CalcS: No; Mask:
. 2020-12-18 09:53:21.886   TM: M; ClAr: No; RemEOF: No; RemBOM: No; CPS: 0; NewerOnly: No; EncryptNewFiles: Yes; ExcludeHiddenFiles: No; ExcludeEmptyDirectories: No; InclM: *>=14D; ResumeL: 0
. 2020-12-18 09:53:21.887   AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; *.js; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2020-12-18 09:53:21.888 Getting real path for '/studentpics/'
> 2020-12-18 09:53:21.889 Type: SSH_FXP_REALPATH, Size: 22, Number: 272
< 2020-12-18 09:53:21.911 Type: SSH_FXP_NAME, Size: 45, Number: 272
. 2020-12-18 09:53:21.912 Real path is '/studentpics'
. 2020-12-18 09:53:21.914 File: '\\aiken\IDPhotos\20170247.jpg' [2020-12-18T08:41:48.262Z] [7946]
. 2020-12-18 09:53:21.917 Copying "\\aiken\IDPhotos\20170247.jpg" to remote directory started.
. 2020-12-18 09:53:21.917 Binary transfer mode selected.
. 2020-12-18 09:53:21.918 Opening remote file.
> 2020-12-18 09:53:21.918 Type: SSH_FXP_OPEN, Size: 50, Number: 515
< 2020-12-18 09:53:21.940 Type: SSH_FXP_STATUS, Size: 24, Number: 515
< 2020-12-18 09:53:21.940 Status code: 4, Message: 515, Server: Failure, Language:
. 2020-12-18 09:53:21.941 Cannot create new file "/studentpics/20170247.jpg", checking if it exists already
> 2020-12-18 09:53:21.942 Type: SSH_FXP_LSTAT, Size: 34, Number: 775
< 2020-12-18 09:53:21.963 Type: SSH_FXP_ATTRS, Size: 37, Number: 775
> 2020-12-18 09:53:21.964 Type: SSH_FXP_OPEN, Size: 50, Number: 1027
< 2020-12-18 09:53:22.025 Type: SSH_FXP_STATUS, Size: 34, Number: 1027
< 2020-12-18 09:53:22.026 Status code: 3, Message: 1027, Server: Permission denied, Language:
* 2020-12-18 09:53:22.027 (ETerminal) Permission denied.
* 2020-12-18 09:53:22.028 Error code: 3
* 2020-12-18 09:53:22.028 Error message from server: Permission denied
. 2020-12-18 09:53:22.029 Asking user:
. 2020-12-18 09:53:22.029 Cannot overwrite remote file '/studentpics/20170247.jpg'.$$
. 2020-12-18 09:53:22.030 Press 'Delete' to delete the file and create new one instead of overwriting it.$$ ("Permission denied.
. 2020-12-18 09:53:22.030 Error code: 3
. 2020-12-18 09:53:22.031 Error message from server: Permission denied")
< 2020-12-18 09:53:22.032 Script: Cannot overwrite remote file '/studentpics/20170247.jpg'.
< 2020-12-18 09:53:22.032 Script: Permission denied.
< 2020-12-18 09:53:22.033 Error code: 3
< 2020-12-18 09:53:22.033 Error message from server: Permission denied
* 2020-12-18 09:53:22.034 (ESkipFile) Cannot overwrite remote file '/studentpics/20170247.jpg'.$$
* 2020-12-18 09:53:22.035
* 2020-12-18 09:53:22.035 Press 'Delete' to delete the file and create new one instead of overwriting it.$$
* 2020-12-18 09:53:22.036 Permission denied.
* 2020-12-18 09:53:22.036 Error code: 3
* 2020-12-18 09:53:22.037 Error message from server: Permission denied
. 2020-12-18 09:53:22.037 Copying finished: Transferred: 0, Elapsed: 0:00:00, CPS: 0/s
. 2020-12-18 09:53:22.051 Script: Failed
> 2020-12-18 09:53:22.831 Script: exit
. 2020-12-18 09:53:22.832 Script: Exit code: 1
. 2020-12-18 09:53:22.833 Closing connection.
. 2020-12-18 09:53:22.834 Sending special code: 1
. 2020-12-18 09:53:22.855 Session sent command exit status 0
. 2020-12-18 09:53:22.856 Main session channel closed
. 2020-12-18 09:53:22.857 All channels closed
Either the path is wrong – Shouldn't it be something like /home/username/studentpics/, rather than just /studentpics/?
Or you do not have permissions to write to that folder.
Are you able to upload the files anyhow? Using WinSCP GUI? Using any other way?
Swindellvc@cofc.edu
Charleston, SC
The Error only happens with certain images...otherwise it works fine.
Is there some setting I need to set that I'm missing?
Yes I can upload with the GUI.
Basically I need to update images on the remote site that have changed or are new in the last X Days.
Can you post a log that shows a successful upload of some image and a failed upload of another image, all other things being equal?
And/or log of a successful upload of an image in GUI and a log of failed upload of the same image in code?
