How to make permissions same for new and transfered files and directories.
jeffshead
US
Below are the permissions that I want to be set but none of the settings in WinSCP accomplish everything listed below:
    - Newly created directories: 0755
    - Newly created files: 0644
    - Transferred directories: 0755
    - Transferred files: 0644
Below are the permissions that are actually set:
    - Newly created files: 0664
Do I have to change a setting on the server or can WinSCP be made to change newly created files to 0644?
Re: How to make permissions same for new and transfered files and directories.
So what is your WinSCP settings for permissions when transferring?
How do you you "newly create the files"?
Note that it might be the server that enforces the 0664 permissions for the new files.
jeffshead
US
For transfers, my WinSCP settings for this session:
How I create a new file (right-click menu in WinSCP)
And if you upload a local file that does not exist in the remote directory, what permissions does it get with the above transfer settings?
jeffshead
If I use WinSCP to upload a file, the file is 0644. If I use WinSCP (right-click create new file) to create a new file, the file is 0664.
Please attach WinSCP session log file showing an explicit upload of a file that does not exist in the remote folder, and an implicit upload of a file created with New > File.
