How to resume transfer?
Angelatop
Dear technical support,
I have 2 issue with Winscp:
1) Each time when i download files from FTP server to my PC, it will overwrite and download again from beginning even if i have 100% downloaded complete file in my PC. Meaning, the transfer will not skip completed file, it will just download whenever i manually drag file from ftp to my pc. May I know how to skip completed file when i do manual transfer?
2) For incomplete files due to connection error etc, it is also the same, transfer will just overwrite and start from beginning, it will not resume or continue from last incomplete transfer.
Is there a setting that i can solve the 2 problems above? I did not change the default preference setting.
Wish to hear from you soon.
Re: How to resume transfer?
I'm not sure I understand. Do you mean that you expect WinSCP to do nothing, when you explicitly drag a file that already exists in the target folder? That seems counterintuitive to me.
