Check file extension for SFTP?
Support or no? If no, add support? If no again, why not? Only other programs I know that supports check file extension for SFTP is Bitvise. There's a nix server that can do it called ProFTP (Bitwise can do too apparently but only runs on windows) but requires you to configure it on compile, so it's not quite out of the box tick this and it works.
