Error: Exception calling "Open" with "1" argument(s): "Connection failed.
RafaelDBA
Brazil
hello, I need a solution to this problem:
Timeout detected. (control connection)
Connection failed."
my code:
param (
    $localPath = "C:\TestesWinSCP",
    $remotePath = "/path/files/"
try
    Add-Type -Path "C:\TestesWinSCP\WinSCPnet.dll"
        Protocol = [WinSCP.Protocol]::"FTP"
        HostName = "example.com.br"
        PortNumber = "990"
        UserName = "YYYYYY"
        Password = "********"
    try
        $directoryInfo = $session.ListDirectory($remotePath)
        $latest =
            $directoryInfo.Files |
            Where-Object { -Not $_.IsDirectory } |
            Sort-Object LastWriteTime -Descending |
            Select-Object -First 1
        if ($latest -eq $Null)
            Write-Host "No file found"
            exit 1
        $session.GetFiles(
            [WinSCP.RemotePath]::EscapeFileMask($latest.FullName), $localPath).Check()
    finally
        $session.Dispose()
    exit 0
catch
    exit 1
Re: Error: Exception calling "Open" with "1" argument(s): "Connection failed.
RafaelDBA
Brazil
follows the log attachment
  • TEL&COM@sftp.sercom.com.br.log (7.07 KB, Private file)
I've asked for a full log file from your code, not just a log snippet. What does that log is supposed to show us? The log seems to be from an idle GUI session.
