OneDrive, Syncronize and files with "&" or ","
Arvy
Sao Paulo, Brazil
OneDrive native app is horrible, so I decided to use WinSCP to automate my sync.
Works fine, but fails in files with some chars like & and , in the filenames.
Script example:
open davs://<mydata>@d.docs.live.net/
synchronize remote -mirror -delete -criteria=either -preservetime I:\DJ /<myuserid>/Audios-DJ
Runs and uploads files ok. But if I run again, it resend some files (not modified):
Anchor (Lush & Simon Remi |       12309 KB | 9085,4 KB/s | binary | 100%
I:\...\Bigfoot - W&W.     |       10549 KB | 8865,8 KB/s | binary | 100%
Eparrei (W&W Remix) - Dim |        9452 KB | 7099,6 KB/s | binary | 100%
Get Back (Junior Kain & A |       16013 KB | 7837,8 KB/s | binary | 100%
Note: I cannot see the files in the interface too! When I open directly (no-script), it shows that I have 903 local files vs 783 remote files. And I cannot see the files with & and ,. If I drag from local to remote, it shows an overwrite alert!
Probably: WinSCP is not interpreting correctly the "list directory" command sent to OneDrive servers, and ignoring those files.
Using latest version 5.17.10.
Thank you.
Re: OneDrive, Syncronize and files with "&" or ","
Please attach a full session log file from GUI showing the directory listing and the overwrite prompt, when uploading the invisible files.
Arvy
Sao Paulo, Brazil
Just removed my email and user id from logs.
< 2021-04-07 13:07:36.088     <D:href>https://d.docs.live.net/-removed-/Audios-DJ/2021/100%20Degrees%20-%20Dubdogz%20^0%20Bhaskar.m p 3</D:href>
  • OneDrive.log (442.81 KB, Private file)
Arvy
Sao Paulo, Brazil
Here is a new log, in "Debug 2" mode.
– connected
– listing
– drag & drop
– file overwritten
– closed
  • OneDrive.log (4.55 MB, Private file)
Arvy
Sao Paulo, Brazil
I can see several lines like:
. 2021-04-09 09:55:57.281 207: Failed to parse href: [https://d.docs.live.net/-removed-/Audios-DJ/2021/Dont%20Let%20Me%20Down%20(Club%20Mix)%20-%20Lucas%20^0%20Steve.mp3]
In fact, the "failed to parse" lines are the missing files in the remote pane view.
Arvy
Sao Paulo, Brazil
Hey there! The issue is fixed!
Replied to you with a screenshot.
Thanks a lot for the fix.
Rogério
