OpenVMS now failing as a connected platform
OpenVMSnic
wigan UK
Using WinSCP with OpenVMS now fails (all versions of OpenVMS, V7.n, V8.n)
It has issues retrieving the directory, and copying files fails with invalid file specificaion (on OpenVMS)
Failed to set default directory to /SYS$SYSDEVICE:[NIC].
file specification syntax error
The extra / at the beginning is causing the problem for VMS. The SYS$SYSDEVICE: IS the disk, there are no / on OpenVMS.
Directory listings fail:
Unexpected directory listing line 'dspppaksipf-com2012-08-31.txt/dspppaksipf-com2012-08-31.txt;1////dspppaksipf-com2012-08-31.txt;1/29696/1/0/2014/3/57/11/30/1/0/1'.
Invalid argument to date encode [2014-3-57]
OpenVMS used to work... FileZilla works and is being used as a workaround for now.
Re: OpenVMS now failing as a connected platform
So when did it used to work? Were you using different version of WinSCP or OpenVMS?
