Automation Script Download Latest file and rename.
Bristow
UK
Hi
I'm using the below script but can not work out how to rename the file once downloaded. I'm trying to download the latest file from a SFTP site and then rename it to a generic name and copy to a local directory overwriting the previous days file.
Any help would be much appreciated.
param (
    $localPath = "C:\downloads\",
    $remotePath = "/Test",
    $fileName = "TestFile.xlsx"
try
    # Load WinSCP .NET assembly
    Add-Type -Path "WinSCPnet.dll"
    # Setup session options
        HostName = "My server.co.uk"
        PortNumber = 22
        UserName = "Test"
        Password = "Test"
        SshHostKeyFingerprint = "ssh-rsa 2048 TEST="
    try
        # Connect
        # Get list of files in the directory
        $directoryInfo = $session.ListDirectory($remotePath)
        # Select the most recent file
        $latest =
            $directoryInfo.Files |
            Where-Object { -Not $_.IsDirectory } |
            Sort-Object LastWriteTime -Descending |
            Select-Object -First 1
        # Any file at all?
        if ($latest -eq $Null)
            Write-Host "No file found"
            exit 1
        # Download the selected file
        $session.GetFileToDirectory($latest.FullName, $localPath) | Out-Null
    finally
        # Disconnect, clean up
        $session.Dispose()
    exit 0
catch
    exit 1
Re: Automation Script Download Latest file and rename.
I'm not sure I understand. If you are asking how to download the latest file from the remote directory to a fixed local path (name), you can do:
$source = [WinSCP.RemotePath]::EscapeFileMask($latest.FullName)
$dest = (Join-Path $localPath $fileName)
$session.GetFiles($source, $dest).Check()
