trying to download group of files with similar names in a script
Muchohombre
Michigan
I have a 2 groups of files. One starts with CERR the other starts with AERR. After that is the date then .pdf ex. CERR20210506.pdf. I would like to download all the files that start with CERR but I can't get it to work and I've looked all over. This is my script:
option batch abort
OPTION CONFIRM OFF
open sftp://DOSxxx:JMSINCxxx@136.182.135.34:2222
bin
get  CERR*.PDF
If I specify the exact file name it works, but I can't get it to do multiple files.
Re: trying to download group of files with similar names in a script
Your script looks correct. If it does not work, please attach a full session log file showing the problem (using the latest version of WinSCP).
Muchohombre
Michigan
The log shows that there are these files in the initial directory /DOSCHB:
AERR078D.210514.0039.311xuhkj
OUT078D.210514.0038.431bgbcq
AERR078D.210513.0131.162gvqll
AERR078D.210512.0139.050hxyzm
AERR078D.210511.0145.280ctx4x
AERR078D.210508.0045.045j325t
FAC078D.210508.0043.1058l0bn
AERR078D.210507.0057.3070sy3h
AERR078D.210506.0001.398uw65d
CERR078D.210501.0044.00yd3sqd
No .pdf files.
