Error copying remote files
link575
I'm getting an error when trying to copy remote files to either local or to another location on the same remote drive. It says
Copying files from remote side failed.
Exception thrown, message: Value does not fall within the expected range.
Any info on what may be the issue? TIA
Re: Error copying remote files
link575
Ok here is the log. I made it private since I have no idea what might be sensitive info in there.
  • winscp.log (5.52 KB, Private file)
"Full" log file please. What kind of FTP server is that? It seems to include some garbage in the directory listing:
> 2021-06-22 11:42:30.922 LIST -a
< 2021-06-22 11:42:30.979 150 File is Ok, about to open connection.
. 2021-06-22 11:42:30.979
. 2021-06-22 11:42:30.979 -rwxrwxrwx   1 owner   group           21528 Jun 20 19:47 Hudson's Adventure Island III (U).state
. 2021-06-22 11:42:30.980 -rwxrwxrwx   1 owner   group          375872 Jun 20 19:47 Smart Ball (U).state
link575
That should be the full log file, I followed the steps you said to enable it. I can do it again if I should be doing something different but it was a normal log. It's an Xbox app called FTP Durango, is that "garbage" something I should be concerned about? I don't know if this helps but when using WinSCP there are files shown on the remote device with no type, name or size and if I specifically leave those out the transfer will work. Really old versions of WinSCP didn't give me an issue and a different FTP program also worked and incidentally don't show these mysterious files.
