Folder upload
shibbycribby
Folder upload
Hi I'm trying to create a script for uploading a folder (with subfolders) to an FTP location. I've got the script to login ok and I tried to use the synchronise command but nothing happens past logging in. I was also wondering if there was a command like put that would upload all folders on the assigned local directory without downloading everything from the remote directory?
Re: Folder upload
Yes, there's a put command that does that you want:
https://winscp.net/eng/docs/scriptcommand_put
If you have problems, please attach a full session log file showing the problem (using the latest version of WinSCP).
Also WinSCP GUI can generate an upload script for you:
https://winscp.net/eng/docs/guide_automation#generating
