Syncing actively written host
I'm trying to synchronize with a remote FTP host which is actively writing files to the remotePath. See code below:
This code will report:
Where
I'm wondering if there is any way to tell
using (Session session = new Session()) { // Will continuously report progress of synchronization // Also copy to Syncdir after download 'File' is ready session.FileTransferred += FileDownload; // Will continuously report progress of transfer session.FileTransferProgress += FileTransferProgress; SessionOptions sessionOptions = new SessionOptions() { Protocol = Protocol.Ftp, HostName = Host, PortNumber = PortNumber, UserName = User, Password = Password }; // Connect session.Open(sessionOptions); // Synchronize files from remote to destination (local) SynchronizationResult synchronizationResult = session.SynchronizeDirectories( SynchronizationMode.Local, LocalPath, RemotePath, false, false, SynchronizationCriteria.Size, new TransferOptions { ResumeSupport = new TransferResumeSupport() { State = TransferResumeSupportState.Smart } } ); // Throw on any error synchronizationResult.Check(); session.Close(); }
WinSCP.SessionRemoteException: Error transferring file 'file.txt'. Copying files from remote side failed. file.txt: No such file or directory at WinSCP.OperationResultBase.Check() at
file.txt
is the actively written file by the remote host.
to ignore files which are actively being written or perhaps there is a different way to handle this situation?
