Display File Size over 32G
teknorob
Problem with display of file size over 32 Gig. Shows up as 233MB, with FTP transfer protocol and Commander Interface.
File is an image of a drive. Reason for large file size.
WinSCP 5.19.2 Windows XP and Windows 7 Same result, will check Windows 10 later on.
Will provide screenshots if necessary.
Re: Display File Size over 32G
teknorob
Here are the screenshots of what I mean
  • WinScp Diag.png (37.61 KB, Private file)
Description: the properties of the file in WinScp
  • 32 GigFile.png (115.24 KB, Private file)
Description: the file Display logged in
  • 32 GigFile Win 7.png (38.56 KB, Private file)
Description: the properties of the file in Windows 7
teknorob
Sending log file
Sorry for the delay
Keep up the good work!
-Robert
  • Ftp.log (10.33 KB, Private file)
The FTP server reports the file as 233 MB.
. 2021-08-13 15:09:23.253 modify=20210809041143;perm=adfrw;size=244436678;type=file;unique=FD02U128C6;UNIX.group=100;UNIX.mode=0666;UNIX.owner=1000; Dell Full Disk Image.mrimg
So it's server-side problem.
You are using ProFTPD 1.3.3, which is over 10 years old. You may need to upgrade.
