System Error. Code: 5.
beacon
Hi All,
I am using CLI to get a (.zip) folder from remote server to my local C drive. I am getting the error
System Error. Code: 5. Access is denied.
I have full access. I am not sure where else to look at. Please see my query
option batch on
open sftp: -hostkey="ssh-r"
option transfer binary
get -preservetime *.zip C:\
close
Please advice.
Re: System Error. Code: 5.
