How to pass session to KITTY, but using SSH-key, not Password-based
Re: How to pass session to KITTY, but using SSH-key, not Password-based
There are two ways to configure KiTTY in WinSCP:
1) With use of registry – In this mode all relevant settings, including the key, is transferred to KiTTY.
2) In portable mode – In this mode the key is not transferred. But you can load the key to Pageant to make it available both for WinSCP and PuTTY/KiTTY:
https://winscp.net/eng/docs/ui_pageant
selnomeria
Many thanks, for the case of portable use, I'll look into Pageant docs. Hope it's easy instruction to do.
But why WinSCP doesn't have a simple way to pass the ssh-key location by parameter to PuTTY? So, avoiding the Pageant middleman.
Well, there are so many things that can be improved. And there are the two solutions for the problem mentioned above.
