Command line for moving files to another folder (ver. 5.19.2 on Windows OS)
Ola
Hello!
I am a new user of WinSCP. And now I need help for moving files. Here is my batch-file now:
"C:\Program Files\WinSCP\WinSCP.com" ^
  /log="C:\WinKboUtsending\WinScpLog\WinSCP.log" /ini=nul ^
  /command ^
    "open sftp://USERNAME:Hb.592-XXXXX@ADRESS/ -hostkey=""ssh-ed25519 256 HT7IB76+WWRiFuCwsl0HznfdI9kfGkk16HQtMY1ndoY=""" ^
    "get -delete /out/*.xml C:\WinKboUtsending\Import\"
if %WINSCP_RESULT% equ 0 (
  echo Success
) else (
  echo Error
exit /b %WINSCP_RESULT%
I want to move (not only copy!) files from C:\WinKboUtsending\Import\ and to
C:\WinKboUtsending\Import\ANOTHER FOLDER
Reply with quote E-mail
Re: Command line for moving files to another folder (ver. 5.19.2 on Windows OS)
I do not understand. Which files do you want to move? The downloaded files? So why don't you download them straight to C:\WinKboUtsending\Import\ANOTHER FOLDER?
Ola
Hi!
XML-files are downloading to /OUT/ every hour.
I download them to my local C:\WinKboUtsending\Import\
But I want to move the files also to another folder f ex under /OUT/
After copying and moving, the files will be deleted in the folder /OUT
Was this better to understand? Thanks for helping me! :)
Before you wrote that you want to move the files to C:\WinKboUtsending\Import\ANOTHER FOLDER, what is local path. Now you wrote "under /OUT/" – what is probably a remote path. So no, your question is still not clear.
Is this what you are after?
https://winscp.net/forum/viewtopic.php?t=28792
