Save last used folder - without automation
nz
France
I searched on this forum and the docs and did not find the solution.
I have to synchronize various SFTP - different connection - different folder into one big folder which contains a folder for each SFTP.
When I synchronize to an other SFTP, it shows my last local folder used by WinSCP and not the last folder used for this specific SFTP (synchronization).
Is it a normal behavior?
Should I do it in another way? Except scripting?
Could it be a feature request?
Thank you,
Re: Save last used folder - without automation
Sorry, but your description is rather vague.
Do you mean that when you login to another session/server, you want WinSCP local panel to show the same folder, as the last time you have used that session/server?
Make sure that Remember last used directory is on:
https://winscp.net/eng/docs/ui_login_directories
and that local panel's Do not change state when switching sessions is off:
https://winscp.net/eng/docs/ui_pref_panels_local
Though both are defaults.
