Reset toolbar positions and configuration to default
da_chicken
US
Recently, I opened WinSCP and went to drag it to a different monitor. Instead of click on the title bar, I mis-clicked on a toolbar, and dragged it off the application. I put it back, but it completely jumbled everything.
I want to reset the arrangement of toolbars to the default. How do I do that?
Please don't suggest deleting the entire WinSCP.ini file or the entire registry. I've got about 40 sessions saved over about 10 years and the last thing I want to do is re-enter all of those.
da_chicken
I think I've managed to fix this. From the Session Manager, go to Tools > Clean Up.... From there, I cleaned up the data for "General configuration". That seemed to reset things for me.
That's one way, though it resets all configuration
https://winscp.net/eng/docs/ui_cleanup
If you want to only reset the toolbars, remove the following registry values:
[HKEY_CURRENT_USER\SOFTWARE\Martin Prikryl\WinSCP 2\Configuration\Interface\Commander]
"ToolbarsLayout2"=...
"ToolbarsButtons"=...
"ToolbarsLayout"=...
[HKEY_CURRENT_USER\SOFTWARE\Martin Prikryl\WinSCP 2\Configuration\Interface\Explorer]
