Specific remote directories not showing in remote panel
RMS2923
I am trying to copy off some files from a RHEL 8 server using WinSCP. The files are in /etc/httpd/conf. When I ls -a from a PuTTY session the httpd directory is there, as are the subsequent files and directories.
When I connect via WinSCP the httpd directory does not show up.
There are directories with the same permissions, etc, that do show up but hot httpd.
Here's the permissions for them. I can see the hp directory in WinSCP but I can't see the htdig or httpd directories.
Ron
drwxr-xr-x.   2 root root   4096 Oct  7  2016 hp
drwxr-xr-x.   2 root root   4096 Oct  7  2016 htdig
drwxr-xr-x.   4 root root   4096 Jul 31  2017 httpd
Re: Specific remote directories not showing in remote panel
RMS2923
Got what I needed
Thanks for the reply. I just wrote the file to a directory I can see and downloaded it from there.
I'll have to save the original mystery for another day.
Ron
