Collect list of filenames from remote directory in local text file using command line
nishit.2571988@gmail.com
Ahmedabad
winscp> call ls \fileList.txt
This is not work
Not work directory listing in separate text file
Expected output
filelist.txt
file1
file2
file3
Ahmedabad
Log or xml log is not work
My code is like below log or xml log is not created. Once xml log is work then I retrieve file listing from xml log.
Process winscp=null;
ProcessStartInfo startInfo=new ProcessStartInfo
  FileName="C:\\Program Files (x86)\\WinSCP\winscp.com",
  RedirectStandardInput=true,
  RedirectStandardOutput=true,
  RedirectStandardError=true,
  UseShellExecute=false,
  CreateNoWindow=true,
winscp.StartInfo=startInfo;
winscp.Start();
winscp.BeginOutputReadLine();
winscp.BeginErrorReadLine();
try
  winscp.StandardInput.WriteLine("winscp.com /log=\"c:\\Users\Test\Desktop\\log.txt\" /xmllog=\"c:\\Users\Test\Desktop\\xmllog.xml\"");
  winscp.StandardInput.WriteLine("open ftp://XXXX:XXXX@XXXX.com");
  winscp.StandardInput.WriteLine("lcd c:\\Users\Test\Documents");
  winscp.StandardInput.WriteLine("cd /'XXX.' ");
  winscp.StandardInput.WriteLine("ls");
catch(Exception ex)
