Read only or Archive files are deleted on local
psimpson
Reported problem - Read only or Archive files get deleted on local, if ‘local’ is accidently selected as the target directory instead of ‘remote’. Note the ‘delete’ check-box in synchronize preferences is unchecked.
Should this be possible to delete read only or archive files without prompting?
WinSCP:
Ver 5.19.1 (build 11552)
Windows server 2016
SFTP (SSH)
Commander GUI
Re: Read only or Archive files are deleted on local
