Cannot remove files having extension ".filepart"
ben37
Hi
Problem : cannot remove .filepart files.
This file was sent by WinSCP with an option "Transfer resume support" and it failed to rename even in case of Admin role.
And then, it's impossible to remove or move these files like below.
The space : Azure net drive <- this space is mounted on the RedHat linux.
Could you tell me how to remove these files?
Any ideas on how to fix this?[/img]
Re: Cannot remove files having extension ".filepart"
This looks like a server-side problem. But anyway, if you want to have us look deeper, please attach a full session log file showing the problem (using the latest version of WinSCP).
