Problems with Rename, Delete and Change
TheRealBasti2021
Hello, I have a problem , If I want to delete a folder / file it says : Failed to delete the file. How can I fix this
Hello, I have a problem when I want to move the folder/file to another folder comes this error message:Internal error renaming the file How can I fix this
Re: Problems with Rename, Delete and Change
Btw, did you edit the screenshot? Or are the files in the remote panel really invisible (unless selected)?
