Using wildcards to access SFTP directory
f4932
Hi
I am creating a SFTP task in SSIS. I followed these steps:
https://winscp.net/eng/docs/library_ssis
The C# script works IF the file paths are explicitly stated. Below is excerpt that works:
TransferOperationResult transferResult;
transferResult =
    session.GetFiles("/order_000053922/item_000098300/file_*", @"C:\Users\Me\To_Be_Processed\", false, transferOptions);
However, the remote directory will have new order and item numbers so the numbers will change but it will always have order and item in the names. I need below to work:
transferResult =
    session.GetFiles("/order_*/item_*/file_*", @"C:\Users\Me\To_Be_Processed\", false, transferOptions);
I cannot use * like this. It complains. How would I code this so I can use * like noted?
Thank you
Re: Using wildcards to access SFTP directory
You have to identify the order and item names first.
For example like this:
var opts = EnumerationOptions.MatchDirectories;
var order = session.EnumerateRemoteFiles("/", "order*", opts).First();
var orderPath = order.FullName;
var item = session.EnumerateRemoteFiles(orderPath, "item*", opts).First();
var source = RemotePath.Combine(item.FullName, "file_*");
transferResult = session.GetFiles(source, @"C:\Users\Me\To_Be_Processed\", false, transferOptions);
Untested + Assuming that there's always only one order and item.
If there are more, let us know how you want to handle that.
f4932
Thanks for the reply. There will definitely be more. Every day there are new files created so each day there new order/item pairs. For example, yesterday it may be order_034/item_229 and today it would be order_882/item_002. There will be multiple order/item pairs. Within each order/item pair, there will be multiple files of format File_YYYY_MM_DD
I need the logic to find all file_* that are within X days of today's date. This means looking at all order/item pairs. If X = 0 then that means only return order/item that equals to today's date. I forgot to include the X days part earlier. Sorry about that.
How would I implement this?
Thank you so much for your help!
