WinSCP not connecting vss IPv6
tommytrant20
vietnam
I using WinSCP 5.19.5 and 1 IPv6.
I input [IPv6] but WinSCP not connect with server.
Why? Please help me? tks.
Re: WinSCP not connecting vss IPv6
What protocol? Please attach a full session log file showing the problem (using the latest version of WinSCP).
Can you connect with any other client using the same protocol? If you can, please post its log file too.
tommytrant20
vietnam
I use WinSCP version 5.19.5 Build 11933 2021-11-25.
I use protocol SFTP, I input host name [IPv6], port number 22, user name and pass, I login WinSCP Notification
Network error connection to "[IPv6]" time out.
Then I change protocol SCP and again login WinSCP Notification
Continue I try chance protocol FTP and again login WinSCP Notification connect Fail.
I try chance protocol WebDAV and again login WinSCP Notification connect Fail.
That's all my manipulation.
Please help me show me the way connecting server vs IPv6.
Tks.
I've asked for logs. And I've asked about other clients. You didn't respond to those.
