AWS server can transfer via GUI but not via scripting
sparkei1
Hi
Version of WinSCP 5.19.6- using version downloaded for automation.
Issue
We are trying to automate to an Amazon AWS transfer family server to send a small csv of hundreds of kb. What happens though is via any scripting or automation the server will only accept one line of csv data. Any more and the server we are sending to times out does not respond and using different software and wireshark found it would fail for 19 seconds with the server not responding. When trying to send via the GUI this issue does not persist which is what is difficult to understand.
We have limited availability to get server side to see why it does not respond. The root directory is "/" where we save to with the AWS url, I saw some notes around this in FAQs but can get files list ok from this directory so not sure where to go around this.
Is there anyone with further WinSCP automation able to advise any ideas of what I can do to get the file to put successfully using a script in this situation/ or point out what config settings on AWS side should be looked into
I have attached an example script. N.B. I was starting to list files in a local directory but it only
Exception calling "PutFiles" with "4" argument(s): "Timeout waiting for WinSCP to respond"
At \WinSCP-5.19.6-Automation\autoscript.ps1:34 char:5
+     $session.PutFiles("dir\test.csv
    + CategoryInfo          : NotSpecified: (:) [], MethodInvocationException
    + FullyQualifiedErrorId : TimeoutException
Re: AWS server can transfer via GUI but not via scripting
An equivalent log from GUI showing a successful upload of the same set of files would be useful too.
sparkei
United Kingdom
Attached logs (2)
Attached logs.
I have $sessionOptions.AddRawSettings("SendBuf", "0") in the script ok on $session.Open($sessionOptions) so it doesn't solve the issue.
  • Logs2.zip (9.1 KB, Private file)
Re: Attached logs (2)
In WinSCP GUI, you have turned off Automatic Resume / Transfer to Temporary Filename.
https://winscp.net/eng/docs/resume
https://winscp.net/eng/docs/ui_pref_resume
The script uses the default configuration, where this is turned on. While it should not be a problem in general, as you are using rare SFTP server, it might have a bug that causes troubles. Don't you have the option turned off in the GUI for this very reason? Won't turning it off in the script help?
Try adding -resumesupport=off to the put command:
https://winscp.net/eng/docs/scriptcommand_put#resumesupport
sparkei
United Kingdom
Hi:
This has no affect. What now happens is the PowerShell script just hangs for slightly longer before failing and will still result in a 0kb file on the FTP server
At C:\temp\Folder\WinSCP-5.19.6-Automation\autoscript.ps1:40 char:5
+     $session.PutFiles("C:\temp\Folder\testusers_202202141 ...
chris.milne@live.com.au
Having the same issue - any hints on the firewall solution?
Hi, we are encountering the same issue with the GUI working, but not a PowerShell script. Have tried the suggestions in this article, however no luck.
Could you shed some light on what the firewall issue was?
