adi.shva@accadiasoftware.com
Israel
Hi guys,
I saw several entries with this topic, followed all suggested actions, but none of them actually solved the problem. I'm using version 5.19.5. Any ides?
Here the the error-message full text:
Timeout detected. (data connection)
Error listing directory '/'.
Thank you,
Adi
Re: Could not retrieve directory listing
Can you see the directory contents in any other FTP client?
Israel
reply in response to Martin's response
Tried with FileZilla and the connection fails there too.
Here is the log from the FTP server (Xlight FTP Server version 3.9.3.2 (x64)):
05/24/2022 21:04:38 (anonymous 185.175.35.178<--185.167.99.191:30021) "150 Opening ASCII mode data connection for MLSD (55 bytes)."
05/24/2022 21:01:36 (anonymous 185.175.35.178<--185.167.99.191:30021) "211 End"
05/24/2022 21:01:36 (anonymous 185.175.35.178-->185.167.99.191:30021) "PWD"
05/24/2022 21:01:36 (anonymous 185.175.35.178<--185.167.99.191:30021) "257 "/""
05/24/2022 21:01:36 (anonymous 185.175.35.178-->185.167.99.191:30021) "TYPE A"
05/24/2022 21:01:36 (anonymous 185.175.35.178<--185.167.99.191:30021) "200 Type set to A."
05/24/2022 21:01:36 (anonymous 185.175.35.178-->185.167.99.191:30021) "PASV"
05/24/2022 21:01:36 (anonymous 185.175.35.178<--185.167.99.191:30021) "227 Entering Passive Mode (185,167,99,191,215,148)"
05/24/2022 21:01:36 (anonymous 185.175.35.178-->185.167.99.191:30021) "MLSD"
05/24/2022 21:01:36 (anonymous 185.175.35.178<--185.167.99.191:30021) "150 Opening ASCII mode data connection for MLSD (55 bytes)."
05/24/2022 21:02:01 (not login 185.175.35.178<--185.167.99.191:30021) "220 Xlight FTP Server 3.9 ready..."
05/24/2022 21:02:01 (not login 185.175.35.178-->185.167.99.191:30021) "USER anonymous"
05/24/2022 21:02:01 (not login 185.175.35.178<--185.167.99.191:30021) "331 Anonymous login OK, send your e-mail as password"
05/24/2022 21:02:01 (not login 185.175.35.178-->185.167.99.191:30021) "PASS *****"
05/24/2022 21:02:01 (anonymous 185.175.35.178<--185.167.99.191:30021) "230 Login OK"
05/24/2022 21:02:01 (anonymous 185.175.35.178-->185.167.99.191:30021) "SYST"
05/24/2022 21:02:01 (anonymous 185.175.35.178<--185.167.99.191:30021) "215 UNIX Type: L8"
Re: reply in response to Martin's response
How do you connect to the server? Is it a local network server or is it over internet? Did you contact the server or network administrator?
adishva
Hello Martin,
I’m connecting via Internet to a VPS. Regarding the server administrator – I'm afraid it's me. If you have any suggestion regarding the settings of the server – I'll be happy to apply them.
Adi
You need to make sure FTP data connections make it through your VPN too, not only the primary FTP control connection.
In general, it's way easier to make SSH/SFTP connections working through complex networks than FTP.
