Keepuptodate error, could not retrieve directory listing, failed to change directory
Raysor
Hey!
I'm new to WinSCP and tried to make a .txt file to use the keepuptodate command, here's the file:
option batch abort
open ftpes://administrateur:admin@192.168.1.152/ -hostkey="15-86-4d-1f-87-8d-84-36-f4-7a-d4-39-bf-50-66-54-3e-2c-53-ce-ce-be-a7-5e-eb-d4-95-a7-31-6b-db-eb"
synchronize remote "C:\Users\THUILLIEZ Dimitri\Desktop\Test" /Fichiers
keepuptodate "C:\Users\THUILLIEZ Dimitri\Desktop\Test" /Fichiers
When I don't do anything, the script works, but as soon as I create a new folder with a file in it, I get the error "could not retrieve directory listing, failed to change directory"
I see a lot of people having the same issue as me but their solutions doesn't work in my situation. WinSCP itself is working correctly though.
Do you guys have any idea why this is happening?
Re: Keepuptodate error, could not retrieve directory listing, failed to change directory
