Use a script to run an exe on the active session machine
Hi, I'm trying to send a file to several machines and then run a script which essentially just restarts the computer so the changes take effect.
Is there a command I could include in my script to open an exe file I need to run?
e.g. after connection is established:
The bold part is where I can't get it to work. I tried just the filename by itself, tried with the
start cmd, etc. I also tried call.
