Identical Filename
malam
Hong Kong
Identical Filename
I see several files in Inbox and they all have the exact same "Name"; their file "size" is different.
Is WinSCP hiding extension or something else that is not being displayed in the Inbox panel?
Re: Identical Filename
No, WinSCP is not hiding extensions. What protocol are you using? Do you have a different experience with any other client using the same protocol? It's more likely some peculiarity of your server. If you want to check us further, please attach a full session log file showing the problem (using the latest version of WinSCP).
