paused filepart is deleted and restarted from 0 on resume
dmitry_20220518
Using WinSCP 5.21.2 (and earlier)
This doesn't happen always, and I can't quite figure out what causes it -- hopefully you can.
I start gzipping a large file 200GB on the remote Linux box, which takes multiple hours to gzip down to 80-100GB
While it's zipping, I start downloading it -- and on most days, it's completed before my 09:30AM cutoff time (before I have to pause it) -- slow VPN
But on days like today, I kicked the download off a bit late the evening before, so I had to pause it at 09:25 by hitting the || pause button
The filepart file was 53GB and sat around all day being that size.
At 16:30, I went to resume the download -- but when I did, the filepart file was reset back to 0 byte and it started re-downloading the entire 100GB file again.
This happens quite often, but not always -- I've had days when resuming it would continue where it left off.
Funny enough if I pause it and then kill WinSCP, and bring it up later -- it almost always picks up the filepart and continues -- it's primarily when I pause/unpause it without killing.
I thought that maybe my VPN disconnects and reconnects midday, or the pausing causes something to be lost or a checksum to be failed, or some other issue
A
Re: paused filepart is deleted and restarted from 0 on resume
dmitry_20220518
absolutely -- I turned on "Debug 1" logging for next time -- not sure if/when it'll happen again, but if it does, I'll send you the log
It's almost like the issue is this scenario, as it seems to not exist (IIRC) when the program is restarted after the pause.
1. Starts downloading a file with filesize X
2. Continues downloading it as filesize keeps growing to it's final size of, say, 100X
3. Manually Paused when the file is complete but not fully downloaded (I have a slow VPN)
4. Manually Resumed after a sufficiently long time (in my case, about 7 hours, but have not tried shorter times)
dmitry_20220518
Able to reproduce
Was able to repro it:
Attached is a zip at Debug=1 with about 8 rotated log files.
By the time I zipped it, the interesting lines moved to MD5.log.6,so look at that fie -- I had hit pause originally around 08:13, and then hit resume around 16:52. I believe the interesting lines are around "2022-09-01 16:52:26.433" on line 74557, and my file I'm downloading is on line 74858.
Had a 63GB local partfile when I clicked resume, then it went to 0 -- the original file is 100GB
I don't have all log files from when I brought WinSCP up for last night's download, but I go up to MD5.log.30 from about an hour earlier -- if you need them later and if you think they'll help
  • 113299.zip (2.08 MB, Private file)
Re: Able to reproduce
Important is this entry:
. 2022-09-01 16:52:37.586 [Background 1] Partially transferred file is bigger that original file.
(I'm aware of the typo, will fix that)
Does it make any sense? Is it true, what the message says?
dmitry_20220518
That would only be true if WinSCP had cached the original size somewhere (like if it cached the growing file's size when it was smaller and tried to compare it much later instead of re-reading the new value)
By the time I hit resume, the local file was 6xGB and the remote file was 9xGB
So there are only a few ways I can see the local 6xGB file being larger than the remote:
  1. WinSCP caching an old, smaller value (most likely to me, if only this never happens if I restart WinSCP, but only when I resume a long-running WinSCP without restarting)
  2. Somehow the Linux SFTP server giving a wrong file size and causing this
If you want to give me a binary with specific extra logging for my #1 case, where you will dump out what file size you think the local and remote files are, and maybe where you grabbed the remote file size, etc – I'll be happy to test it all week until we catch it
At the time of the resume, the server claimed the file is 2.4 GB:
. 2022-09-01 16:52:37.586 [Background 1] File: '/mdata/hobo/20220831_tape.tape.gz' [2022-09-01T02:48:40.000Z] [2439249920]
dmitry_20220518
Is it possible there's something not passed to the "[Background]" thread between these two lines from my file ?
So at this time, the response shows correct timestamp and file size:
2022-09-01 16:52:29.569 20220831_tape.tape.gz;-;96797290190;2022-09-01T07:23:53.000Z;4;"" [1001];"" [1001];rw-rw-r--;0
But 8 seconds later, on the Background line, it shows the stale data
2022-09-01 16:52:37.586 [Background 1] File: '/.../.../20220831_tape.tape.gz' [2022-09-01T02:48:40.000Z] [2439249920]
Both are direct responses from the server. Just using different API. The first is directory listing (SSH_FXP_OPENDIR/SSH_FXP_READDIR SFTP requests), while the latter is file attribute request (SSH_FXP_LSTAT). If you post Debug 1 log file, I can double check that, but I do not think it will bring anything new.
dmitry_20220518
Those lines were from the log file I submitted – if they are both responses from the SFTP server, then maybe the SFTP server does have a bug.
I'll be away for a few weeks, I can pick this up again in October – as a work-around, I'll probably just restart WinSCP if I need to pause/resume on growable files.
Thanks for looking into it!!!
It might not be a bug of the SFTP server as such, it can just be the underlying file system reporting inconsistent sizes for opened files.
