After run script folder is deleted
Odeargre
Portugal
After running the script the folder Cartas_Garantia is always deleted with the files, i only need to delete the files.
The remote directory is /wortends/CartasdeGarantia/Cartas_Garantia/ after running the script the remote directory stays like this /wortends/CartasdeGarantia/.
# Automatically abort script on errors
option batch abort
# Connect to remote machine
open sftp:(...)
# Change remote directory
cd /wortends/CartasdeGarantia/Cartas_Garantia/
# Download file to the local directory D:\FTP\IN\Teste
get -delete /wortends/CartasdeGarantia/Cartas_Garantia -filemask=Carta*.pdf  D:\FTP\IN\Teste\
# Disconnect
close
# Exit WinSCP
Re: After run script folder is deleted
Instead of selecting the folder for the transfer, you need to select the files in the folder:
get -delete /wortends/CartasdeGarantia/Cartas_Garantia/* -filemask=Carta*.pdf  D:\FTP\IN\Teste\
Or, if the download is not recursive a simpler syntax:
get -delete /wortends/CartasdeGarantia/Cartas_Garantia/Carta*.pdf D:\FTP\IN\Teste\
See https://winscp.net/eng/docs/scriptcommand_get#remarks
Jan1111
Germany
Is there a solution for dynamic Folder-Names? In the example the Subfolder Cartas_Garantia is a static folder with static name. In my case the folders were creates automatically and all I know is, that they beginn with 20*.
Thanks alot!
Not with simple WinSCP scripting. You would have to use more powerful language, like PowerShell with use of WinSCP .NET assembly. After all, you already have such script.
Alternatively, keep your original solution and move the downloaded file one level up after the transfer.
