Fingerprint SFTP connection variable assigned PowerShell
Madeproel
I have a PowerShell script in which the credentials are set dynamically via variables. For hostname, username, password this works. But not for the fingerprint. I always get the following message:
New-Object : The specified value is invalid, or the property is read-only. Change the value and repeat the operation.
Here is an excerpt of my script. The values was replaced by "xxxx".
function getCreds(){
    $creds=[PSCustomObject]@{
        hostname = ''
        username = ''
        pwd = ''
        fingerprint = ''
    $creds.hostname = 'xxxx'
    $creds.username = 'xxxx'
    $creds.pwd = 'xxxx'
    $creds.fingerprint = 'ssh-rsa 1024 xxxx'
    return $creds
function transferFile($creds){
        HostName = $creds.hostname
        UserName = $creds.username
        Password = $creds.pwd
        SshHostKeyFingerprint = $creds.fingerprint
$creds=getCreds()
Paul Martell-Mead
Same here
I am seeing the exact same behaviour here.
I have an INI file containing the settings for the script which reads key/value pairs into PowerShell variables. All parameters work fine this way except SshHostKeyFingerprint. I can use my SshHostKeyFingerprint value hard-coded in the script and it works fine, so this proves it isn't an issue with the actual value (which is what the above answer implies).
Paul Martell-Mead
Figured it out
Right – so the issue for me is I had the value enclosed in quotes and this won't pass validation for the fingerprint.
