Put command is appending to file using the Wasabi service
sam@...
open ftp://user:pass@s3.us-central-1.wasabisys.com
put swanndvr.netnew2016.vhdx /sams-daily-ddns/64.251.23.131/
put 4khdcamera.com.vhdx /sams-daily-ddns/64.251.23.131/
put 416nvr.com.vhdx /sams-daily-ddns/64.251.23.131/
put fptddns.vn.vhdx /sams-daily-ddns/64.251.23.131/
put ippostcode.com.vhdx /sams-daily-ddns/64.251.23.131/
put livesierra.vhdx /sams-daily-ddns/64.251.23.131/
put mymeriva.com.vhdx /sams-daily-ddns/64.251.23.131/
put sierradns.com.vhdx /sams-daily-ddns/64.251.23.131/
put epsconnect.net.vhdx /sams-daily-ddns/64.251.23.131/
put tecproddns.vhdx /sams-daily-ddns/64.251.23.131/
put agddns-newddns-ghiddns2016.vhdx /sams-daily-ddns/64.251.23.131/
The above script appends data while I need to overwrite etc.. Please advise.
Re: Put command is appending to file using the Wasabi service
In general, the code overwrites. If it appends, it's most likely a special "feature" of the server.
Can you overwrite the files in WinSCP GUI? Or in any other FTP client? If you are, post logs both for appending issue with WinSCP script and successful overwrite using any other tool.
