WinSCP.com use option batch continue
I have an error while transfering some files (even by using WinSCP GUI)
However file is well transferred! But it stops the other transfer. So I would like to skip such error.
I found that I should use
Here my bat file script:
How can I add
Failure reading network stream.
but I don't understand how?
"C:\Program Files (x86)\WinSCP\WinSCP.com" /command ^ "open ftps://****@**** -explicit -certificate="***" -rawsettings MaxTlsVersion=12" ^ "cd /ftpdir" ^ "put C:\DATA" ^ "close" ^ "exit"
C:\DATA
is a folder with some files that I want to transfer to my FTP.
How can I add
