SCP session into a Raspberry PI with Shell "sudo su -" enabled fails with "Error skipping startup"
wspnu
connection attempt by using user creds who has root access fails with this error message:
Error skipping startup message. Your shell is probably incompatible with the application (BASH is recommended).
WinSCP version is 5.21.5 - build 12858.
Since I need to access folders on my RPI that require root access: How to fix this error?
Re: SCP session into a Raspberry PI with Shell "sudo su -" enabled fails with "Error skipping startup"
