Deleting folders with space as the first char, doesn't work
Topic says it all.
I'm aware I'm on a fairly old version but I would assume nobody noticed the issue yet. ;)
Consideration:
I didn't test it, but I would guess same issue exists not only for folders but for regular files too.
Work Around:
Rename file and remove the first space then delete.
OS: Windows 10
Version: 5.17.1 (Build 10240)
PS: Awesome that I can post without registration! Keep it up like that! :)
Consideration:
Work Around:
OS: Windows 10
