Execute script using exernal parameter
luk3tt0
Italy
My script is:
C:\tools\winscp-5.21.5\winscp.com /script=C:\projects\test-sync-ftps.ps1
test-sync-ftps.ps1 contains:
option batch abort
open ftp://xxxxxx:yyyyyy@zzz.zzz.zzz.zzz
I'd like to pass hostname, username and password dynamically.
I tried to use /parameter attribute but it does not work:
C:\tools\winscp-5.21.5\winscp.com /script=C:\projects\test-sync-ftps.ps1 /parameter xxxxxx yyyyyy zzz.zzz.zzz.zzz
open ftp://%1%:%2%@%3%
How can I solve it?
Re: Execute script using exernal parameter
I've tested your script and it works for me as expected.
Make sure your credentials do not contain any special characters that might be misinterpreted by the batchfile (cmd). Like percent or caret signs.
If you still have problems, please attach a full session log file showing the problem (using the latest version of WinSCP).
Btw, it's confusing to give WinSCP script a .ps1 (PowerShell) extension.
